Slow retractable seatbelt
cairnsGU
To go with what Jamus said from memory nissan do a sticker pack thing. The sticker goes into the top loop.
Supposed to make them retract better.
If you have a look at the top loop - lift the seatbelt you'll see there normaly caked with dirt.
If you rub this of it helps alot aswell.
Edited by gottheshits
When mine became really bad a couple of years back I washed and rinsed them thoroughly on a hot day and hung them over the door to dry, I would not put silicone spray on the runner as this gets back onto the belt and attracts dust further exacerbating the run through the top mount.
What I did find was some built up gunk on the top of the runner slot which when I removed, restored some extra return force into it, they were never brilliant so don't expect too much.
There are a number of teflon/mylar tapes around that can be used to improve friction just need to make sure you get a very thin one.
Edited by geeyoutoo
  • 6 months later...
  • 6 years later...
